Offset Disc
I bought used taylor offset. It has large spring in front with threaded bolt running through a long spring. its adjustable on top and bottom.
I'm assuming this sets tension on gangs?
It also roller coastersback and forth during transport???
Probably slop in the tongue causing it to sway going down the road . The bolt and spring probably lets the disk float independent of the tongue
