IH mower I.D.
Cjet
Just had this mower given to us. I don't see a tag on it anywhere so, What model is it?
It is a balanced head mowerfrom either the 100 or 1000 series. Appears to be semi-
mounted which would be a 120 or comparable later model. Ver nice mower. From rhe
picture may be missing a mounting bracket or hardware. Cant tell for sure.
Thanks for the info, guy's. The hitch mount is missing, but looks like something that can be built without too much trouble. I think the next step is to get it unloaded and check out the wobble drive. I that looks OK we will see if we can get it up and running.
(quoted from post at 17:42:53 09/09/17) if the gearbox shaft that holds the flywheel is 5/8", 100 mower. if the shaft is 3/4", model 1000.
I'll check that out, Thanks.
I believe this is the hitch mount I need to find or make for this mower. I will also need a PTO shaft.
