336 bale thower
Dave
I see no reason why you can't utilize the pump to power something else. I looked on JDparts.com & there were no spec's listed for the bale ejector pump.
Jim
Best I've been able to track down is it could be one of several pumps, all with similar specs. The Cessna pump I was able to find some info on. It could be a 25508xxx ('not sure on the exact option codes) which is a 3.37 cubic in per revolution, which is rated at 23 gpm@1800 rpm, 3000 psi max. I believe the baler pump is counter clockwise rotation.
