WANTED: Pulley for Chopper
(quoted from post at 11:10:59 09/07/17) Anybody know where I can get a belt pulley for a PAPEC Model 81 Chopper?
Robert[/list]
I guess I was hoping someone would have a PAPEC that model. I would have to measure all that, unless by some chance someone has all that info.
It should be a flat belt though. The mounting has for bolts. It currently has a tire instead.
I may be able to help you out. I have a couple of Papec parts machines. Both model L's which I think
used the same pulley, but I will need measurements to know for sure.
Robert. If I am not mistaken on what you have it is the stationary silo filler, not a pull type forage harvestor as others seem to be I think thinking of. So that pulley should be one that takes a 6" wide flat belt to drive it from the belt pulley on your tractor. If that is so then figure out the speed in feet per minute of the belt from your tractor then figure out the speed of the shaft you are running and then you can calculate diameter needed, then with that and shaft size start hunting at tractor show parts swap meets., If a keyway is not quite correct that can be modified to work.
For measurements on pulley that I need, I don't have one to take measurements on. I do know it is a Papec Model 81.
