This message is a reply to an archived post by Diydave on August 12, 2012 at 04:28:40.
The original subject was "Re: Case 8430 baler".
Question on a Case 8430. I found this thread and thought your Heston experience might give me some guidance... I recentlly bought a 8430. I've baled roughly 35 bales with it. I'm using a 1066. The belts won't turn when I turn PTO on. Slack adjuster knob is all the way in. I spoke with local Case dealer. No help. I looked at my bale tensioner (valve assembly) and it has 4 brass fittings on the bottom. Dealer says it should only have 2. Valve looks like installed at factory. Any guidance? I tried initially on an AC 180 had same result. Come to find out 180 port pressure is 1800PSI. Manual for baler says it needs 2200. So I hooked to 1066 then after 35 bales this happened. Thanks in advance.
