Hdonly
- Location
- Florida Panhandle
I have spent the last few days (in between the rain and heat) tightening bolts and readjusting braces and adding more braces. My backhoe is much more stable, but I am still not satisfied. I believe that I will end up with a sub-frame from front to back of the tractor. My rear lift is very weak on this tractor anyway, so I may just do away with it and dedicate the backhoe permanently to it. Previous owner broke a piece out of the housing inside next to the hydraulic oil pathway. I have made some attempt to repair it, but it has failed. I think a FEL will be in the future after I build a sub-frame. The backhoe is quite usable, but just not as tight as I would like.
