IH 46 baler gearbox replacement
Al L. in Wisc.
I'm seeking help in the 'how-to-remove' the shaft from the top of the gearbox in order to replace the gearbox as the top bushings are bad. The manual states to remove the shaft upward from the gearbox I've enclosed photos. Thanks in advance for input.
[/img]
I've never had to do this personally, but the attached picture should get you an idea on how to take the thing apart. There's a spanner nut on the bottom of the shaft you're trying to remove. Removing that one, you should be able to pull that shaft out of the gear.
