New Holland Bearing Generic Number
don't know if this helps but napa # BRG 209kRRB2,$74. Deere (A and I) A-209KRRB2-1, $37.60. New Holland $78
80286909 supersedes to CNH part number 47577178 I haven't found any inexpensive generic bearings that interchange. Sometimes you can find the same bearings at a cheaper price on ebay, but someone has to be selling some (I didn't find any).
My wife is from Moses Lake, Washington. She told me to try Moses Lake Bearing when I was searching for some obsolete bearings for my Ferguson mower. I was able to find bearings locally however. Later I was searching online and found a cross reference chart that gave me about 30 different numbers. I don't remember the name of the site.
What is the actual brand on the bearing and the bearing number if it is different from the New Holland number? That is how I had to find my mower bearings.
I had a similar problem, took bearing to NAPA, they measured it up and gave me the proper bearing. The bearings have numbers on their sides and this you should keep for future reference. I learned this very quickly when I replaced bearing in the transmission of my JD/L vintage ~1940.
(quoted from post at 20:15:34 08/02/17) Internal hex bearing?
SKF 209KRRB2.
Is this it?
I do believe it is.
SKF 209KRRB2.
Case Corp: 179665C91 (new Case Corp part # 47577178).
New Holland: 286909 (new NH part # 47577178).
Case/New Holland: part # 286909.
John Deere: part # AE40895.
As a follow up got the bearing from Bearings.Parts for around $15+$10 shipping,came Friday.Installed it this morning on the baler fit perfect.The Number of the bearing
was 209KRRB2 BTW.
