New Holland 479 Hay Bine u-joints
Genz
I'm hoping someone has a parts manual for this unit they'd be willing to share. All the u-joints need replacing on the PTO assembly and would be nice to have OEM part numbers so that maybe the local parts store could cross reference them to other brands. Any input would be appreciated.
Thanks Charlie - I've been to this site. It appears you can only buy the kit, which contains (I don't know) everything needed to rebuild the assembly. I was hoping for an individual u-joint part# that I can hopefully cross to another brand of joint. I hope this joint is not a proprietary item exclusively to New Holland.
It will be a common agricultural Ujoint.Just measure the cap size and the width. They can determine from that.No 'fancy' part number will be needed
Get the parts numbers from Messics web site and take to napa. Deere can also cross the numbers. I looked one u joint up for you machine and deere has one for $23 and napa is $21
