New Holland 276 Baler - PTO Questions
dhermesc
The former owner of my "new" 276 baler was a complete moron. I have spent a lot of time (and money) replacing his half arsed repairs repairing years of neglect. This one has me puzzled though.
The long shaft of the PTO has been replaced - the long tube appears to be original but I don't know for sure. He also replaced the short PTO shaft with something from TSC that is undersized. The long shaft was too long and prevented the tube from sliding all the way back. How he didn't destroy the clutch on the front the flywheel is amazing - but it didn't appear it had seen much use since he had installed it. I took it apart and cut 4" off the long shaft which allowed the tube to slide to the base of the long shaft. I need to take it apart again and clean everything up. Even with oiling the shaft when I put it back together there is considerable resistance in the shaft moving back and forth - almost like it has tar inside gumming it up (excessive heat?). The short shaft is too short - the PTO support is leaning quite a ways forward to hook up - I am guessing he did this to give the PTO shaft some travel for uneven ground.
Right now the only things that MIGHT be original to the baler's PTO is the long tube and the PTO support - although those could have been savaged from a junk pile.
How much travel should there be in the PTO shaft when its hooked up to the tractor? How close to vertical should the PTO support be when hooked to the tractor? I
Can you cut a section off the tube and the shaft to give the PTO more travel?
Currently when fully collapsed the shaft slides all the way up the tube to the knuckle on the end of the tube and the tube is at the knuckle of the shaft. I propose to cut 2-3 inches off of both to give it more travel - and buy the correct short shaft to hook up to the tractor. Even if the PTO shaft was fully extended to the maximum length the support would allow there would still be about 2 foot of the shaft inside the tube.
What I should do is replace the entire PTO shaft and start over but finding a complete unbent PTO shaft for a 30+ year old baler isn't that easy.
The front shaft should be rigid/nontelescopic. Only the long rear section telescopes. the PTO support needs to pivot to allow for turning and such.SSo,if the front(and rear) telescopes,you are headed for a 'wreck'.Fix it right. Consult a manual,look at another baler,or talk to the dealer.There are specific measurements,the book will line them out.The most important is 16" from the center of the drawbar hole to the end f the pto shaft. Keep the tounge parelel to the ground .The driveline should be in a straight line from tractor to baler.
The front shaft is a fixed length - just short. I have located another "factory" short shaft to replace the cobbled up shaft currently in use.
The owners manual gives a measurement from the drawbar to the PTO shaft. Its doesn't take into account the previous owner messing with the shaft lengths. If I knew the correct length of the tube I would probably be set. As I said this could be the correct tube for a 276 baler or it could be something that he found in a scrap pile and bolted on after ruining the original PTO.
dhermesc, read Delta Red's and Roger in Iowa's posts.
Read Delta Red's and Roger in Iowa's posts again.
Yes read them another time yet.
