How to ..NH276 baler pickup removal
Hay hay hay
It looks like taking the shaft out of the pickup will allow the entire pickup assembly to be removed for repair.
How about some practical tips for removing a pickup assembly from a NH276 baler.
2 years ago I had to replace the bearings on the pick-up shaft on my NH 269. Would have never accomplished with out a die grinder and an acetylene torch. I had to get new bearing keepers? with my bearings as the out side diameter of the new ones were different and the original number was no longer available. Have a gear puller to get the chain sprocket off, I had to use a lot of heat and wax and pb blaster. The bearing had to be cut to remove it from the shaft, but all that was left was the part on the shaft. Had to remove some of the pick up guards to get room to work also, both ends. Not much help but perserverance and patience and a little bullheadedness ( I can do this)are needed lol gobble
