Hello all, I'm new to the forum and rather new to hay making. I purchased a case IH 435 square baler in good condition this year. When I purchased it was baling perfect. Started baling hay that was down and fine tuning the bale chamber adjustment to create the perfect size bale. All of a sudden I am having bales with one side not tying on me! So aggravating, two weeks later and one ruined hay field, I still cannot solve the issue. I have adjusted twine disk, tried playing with the billhook tension, have attempted adjusting the needle but now I'm unsure if it is correct or not. I have changed parts, replaced the knife blade. I have went through most of the adjustments that relate to the knotter from the manual and still cannot get the outside knotter to tie. The twine is wrapping around the bill hook roller and not able to be strippped off by incoming hay. I first thought it was the disk timing but I have timed it several times and no changes. I can post pictures tomorrow but the twine is not always catching in the small notch that holds the twine in the disk, the disk is also setting identical to the side that ties in the home position but other times of the cycle it does not match, I don't know what else to do or to try. Hoping somebody with tried and true experience can help!
Thanks in advance.
Thanks in advance.
