Harrow Plow - Help Identify Model
RTR
Picked up this recently and I know it's a harrow plow and not sure the make or model. Thinking about parting it out or selling whole depending on interest. It looks like IH to me but haven't seen any markings yet. I know it's larger than the Cub 12-D I have.
Looks like a oneway disc plow to me. Don't have a clue as who made it, there should be casting numbers on it somewhere.
(quoted from post at 08:51:05 07/14/17) What is the casting numbers on the pie weights on the wheel in the picture,
are there any letters with the numbers?
Not sure I need to look at that. I'm guessing it is IH but it could be anything. The guy had mainly IH and JD tractors
(quoted from post at 09:30:49 07/14/17)
The pie weight is IH part #PO1038 which is a 22 lb weight like found on the Cub 12-D Harrow Plow. I imagine it was used on most model plows. It is definite made by IH.
(quoted from post at 22:21:41 07/14/17) Yep your right, its a disc plow. I cant see how many disc tho. Cant be many.
It has 4 blades. They are spaced too close for a plow I think. That is why I call it a harrow Plow. The plow blades have been removed from the plow as a whole gang. They are sitting at the front of the trailer separatly if you look close. Don't confuse the disk harrow sitting next to it with it.
