NH 850 Baler tie mechanism
Hey folks,
Trying to resurrect a NH 850 that has electric tie mechanism.
Wonder if anyone out there has one that they would be willing to take a few pics of how the cable runs on the roller and disc. I'm missing the cable ??
The real trouble is the worm shaft and piston that works the limit switches seems rusted solid in the block ????
No cable or control box...although likely can rig up a switch of some nature to work the electric motor. ????
Good news is the motor seems to want to move when jumped.
So if anyone might have some of these parts I sure would appreciate it if you give me a shout. THANKS!
On page 26 in the owners manual there is a very good picture of what it should look like. It would be a good idea to get your self the owners manual because with out it there are things you need to know that if you do not know them can lead to major problems down the road. I have 2 NH850 balers one is electric tie and the other is hand tie.
Cost of the manual was around $30. If I still had a scanner I could scan the picture but my scanner went with the old computer going down. Things you need to know are things like going to slow can cause you to make a bale that is super heavy and you cannot get a spike into. Also you need a tractor with at the very least 55 strong HP but less then 75HP again as per the manual. The first year I had my NH850 I made bales that I could not pick up with my Ford 841S because the rear tires would come off the ground
