So I picked up a few New Holland rake teeth today at Orscheln's But the odd thing is they had 2 different NH teeth. One which is a bit heavier duty as in bigger around and bigger spring area. It say it replaces part #64562. The other one which seem lighter duty say it replaces part #40917. But if you lay them side by side they look the same other then how heavy they are. I hope that can make one or both part numbers work on this IH rake I have and if they do I should have almost all the teeth back in place. i know if I can make them work from now on I am likely to use the heavier duty teeth. So is that what you would do if you where doing this???
Thanks
Thanks
