Ok, am I missing something? I have a JD 630 discbine that I am trying to get the cutting height adjusted up, currently it is cutting around 2 - 2.5". I have the skid shoes in the 3rd hole (as low as it goes) and the turnbuckle turned in as tight has it goes. If I remember correctly from the manual with those settings I should be around 4".
The only thing in the hitch setup that is not what the manual calls for is the drawbar being turned up instead of down. If I turn the drawbar down I am below allowable work height. With the bar turned up everything is right where it needs to be.
I don't mind getting skid shoe extensions if necessary, but I'm just not sure what I'm missing to get the height up without them...
