Ok, I could go buy a new loader but where's the fun in that. Sooo, I have a Dearborn 19-22, Single Action Lift Arms and Trip Bucket. I have learned to manipulate the trip bucket but not exactly what I want. What I am going to do, for the fun of it, is to first add a hydraulic cylinder to control the bucket. The bucket has a right side bracket for connecting a cylinder and the old manual shows the conversion to hydraulic cylinder with a mounting kit.
First challenge is finding a trunnion cylinder with the right bore and stroke. Second challenge is fabricating a mounting bracket for the cylinder. Best guess on a bucket cylinder is:
Dual Action, Front Trunnion, 2 1/2 inch bore, 1.5 inch rod, 14 inch stroke, 1500 psi -- Not exactly easy to find and this is a guess so headed to a hydraulic cylinder shop to see what they know.
Then comes the hydraulic valves and plumbing. This is a 51 8N by the way with a Vickers front mounted hydraulic pump. It has a single control, single action valve for the lift and is factory original. It leaks by the way. I will need to go to dual control, dual action valve set but for now will leave the lift arms as single action cylinders. I will change those later. I am thinking one of the following valves will work for the upgrade:
https://www.surpluscenter.com/Hydraulics/Hydraulic-Valves/Directional-Control-Valves/2-SPOOL-8-GPM-PRINCE-MB21BB5C1-DA-VALVE-9-7862.axd
https://www.surpluscenter.com/Hydraulics/Hydraulic-Valves/Directional-Control-Valves/2-SPOOL-8-GPM-PRINCE-MB21GB5C1-DA-VALVE-W-FLOAT-9-7862-F.axd
It appears that the second has "float" but, new to plumbing hydraulics, I don't know if I need that. I am also assuming the jungle him pipes hold enough hydraulic fluid for both the bucket and lift since it is same assembly as used on the 19-23.
I appreciate any input on this project. Again, I know I can get something better and cheaper by just buying a new loader but what the heck, this is a hobby anyway. Ranks right up there with my care restorations.
Thanks....
Thanks....
