Lazy WP
The monitor will do nothing other then tell me the shape of the bale, and sometimes when I need to tie. Sounds like the have been running the manual toggle switch for a while. When I first hooked it up it said the gate was open. Readjusted the latches and micro switches, but the "stop"sign is still flashing and nothing else works.
I just got done baling a couple hundred bales with it, but I would like to get everything back to working order. The book doesn't tell me much other then maybe a blown fuse in the head of the monitor. Checked it and it reads ok with an ohm meter.
Check out connection hookup. Have had a few pins bend when hooking them up and things don't work like you are describing.
1st & foremost you need to get gate latch switches operating correctly because as you're aware that affects other monitor functions. Do you have BaleTrak Plus monitor? I agree to check pins in harness quick connector.
Yep, got te
he bale track monitor plus. I have the tail gate working. It latches solid, and both switches are working and set. I will check the pins today.
