More hay equipment questions
MoMike
I need to put a new conditioner roll tension cable on a PT7 haybine, do you have adjust the cable after installation to equalize both sides? 2nd question, on NH 273 baler does the flywheel shearbolt sleeve go with the shoulder between the flywheel and the drive hub or does it go in the milled slot on the back side of the flywheel? Looking at a parts diagram online it appears the shoulder is in between but on mine it in the slot on the back. Just want to make sure when I change it out that I install it correctly. Thanks
