Hello quantech
James Howell
"<font color="#6699ff">[b:654c4848f0][i:654c4848f0]Do you have a tip for bolt removal, and then replacement with bolts that have the right size nuts for the hex slots?[/i:654c4848f0][/b:654c4848f0]</font>"
This is one method of removing and replacing the cutter bar cap screws.
First block up the support and yoke.
a162646.jpg" width="650"
Block up the frame.
a162647.jpg" width="650"
Block up the cutter bar near the inner shoe.
Leave enough room to work underneath with a wrench.
a162648.jpg" width="650"
Block up the cutter bar near the outer shoe.
a162649.jpg" width="650"
Remove the inner shoe.
a162650.jpg" width="650"
Remove the smaller shoe and dowel pin.
a162651.jpg" width="650"
"<font color="#6699ff">[b:654c4848f0][i:654c4848f0]the four bolts under the inner shoe that secure the cutter bar cannot back out as the nuts spin the in the hexagonal "seats"/"valleys" making it impossible to get a wrench on the nuts to keep them from spinning.[/i:654c4848f0][/b:654c4848f0]</font>"
Apply a abundant amount of your favorite penetrate to the lock nuts.
Use a large, flat-head screwdriver.
Drive the flat-head between the lock nut and the ?hexagonal "seats"/"valleys" as tight as possible.
Keep one hand on the screwdriver applying pressure and the other hand on the wrench.
The ?wedged? flat-head screwdriver should keep the lock nuts from spinning.
Be patient because this might take a while to remove the back cap screws.
You might consider using Category 8 cap screws.
a162654.jpg" width="650"
Replace the lower shoe using the 5/8 x 2 cap screws and lock nuts.
The parts catalog lists a 5/8 x 2 ? cap screw, but the shorter 5/8 x 2 cap screw allows better clearance for the knife drive yoke.
a162655.jpg" width="650"
Continue replacing the lower shoe using the 5/8 x 2 1/2 cap screws and lock nuts.
a162656.jpg" width="650"
a162657.jpg" width="650"
Replace the dowel pin.
a162658.jpg" width="650"
Hope this helps.
