Kuhn tedder GF440T
I am looking for used parts for my Kuhn tedder model GF440T. Specifically the yoak and pin where the out side and inside basket fits together to make the out side baskets spin as well as other small items. Anyone have any contact information of someone who may have parts tedders. Thanks
(quoted from post at 06:06:56 06/12/17)
(quoted from post at 17:29:42 06/09/17)
I should be able to help you out Ray.
Do you have a number I can call. Thanks
Ray, I am in the process of making a new 440 out of parts of two. I will know in a few days what I can spare. My number is 603.three 00. 8one7one.
(quoted from post at 07:55:03 06/12/17)
I will call you at the end of the week. Thanks
(quoted from post at 09:14:36 06/12/17)
Ray, I went for parts today. I went to the bearing store for bearings and seals. Then to the Kuhn dealer for the metric shaft keys that I needed. I had no extra joint pins so I picked one up. They have both the pins and forks on hand and they don't cost a lot. The pin was $18.00. Be aware though that there is a serial number break, because later pins take a sleeve that is held onto the pin by a roll pin, so the opening in the fork is wider to accommodate the sleeve. I plan to weld up and grind down my pins to get more life from them. I have already built up worn forks by adding weld into them.
