Hyd. Gauge on a JD 530 Baler
Hyd gauge shows how much hyd pressure is being applied to hay forming belts. IIRC when gauge needle is next to red area 2500 psi is being applied.
So the hyd. pressure is changed by how tight you want your
bales by using the knob inside of the right side door?
Thank you for the info. I remember it now. So there is no bale
by bale reason to look at the gauge. Unless just to make sure
it still has the right set pressure.
You're welcome. Only reason to check gauge is if bales seem soft or tension valve knob has been turned. Bale core must be formed for gauge to read correct baling pressure.
