1219 JD mower conditioner. Knife remove
VicS
Location
SE Il.
Does the pin pry out the top of the pitman arm? Only way I can see to get knife out. Thanks Vic
Yes the pin comes out the top of the arm. Use a chisel as a wedge to spread the arm ends (BE CAREFUL and not over spread and break. Then pull the pin up and out.
Thanks. But there is a tang on the big pin. Wouldn't come out unless pinch bolt is all the way out. Thanks again Vic
