This part goes underneath each drop area, below the box.
It is metal
It is around 5-6in long. It is built differently starting from the middle outward
One end is around 1in wide and has a slight curve It has a pin that runs through it crossways at the upper middle between the 2 shapes.
The upper shape is around 3/8ths wide and 1/4in thick. It has one hole at the top end of it. To its side is a tin piece fastened at the middle of the whole piece, or said another way, fastened at the bottom of this piece with the hole. If the metal piece is still intact, there is a bulge sticking out at the upper end.
This piece helps regulate the flow of seed. It moves by the pin mentioned and pivots in its middle. The user lines the upper piece to one of 3 or 4 holes onto the piece it is pinned to which is the piece that is screwed to the bottom of the box. When lined up correctly the bulge on the tin piece goes through the hole on the arm its attached to and into one of the slots on the piece the whole piece im needing is attached to. Sure hope to hear that someones got this piece. Thanks for any help beforehand
It is metal
