buster bar vs. coil tine
Fordfarmer
I have an IH 4500 Vibrashank with a 3-bar coil tine harrow. Generally happy with it, except I wish it had tandems and was a little wider (bigger tractor now than when I bought it). There's a bigger field cultivator not too far away for a reasonable price, but no harrow. Found a Midwest Buster Bar at on online auction that should work, but I have no experience with them. How well do the smooth the ridges a field cultivator leaves? Would I be happy with it after running the coil tine?
The Buster Bar is intended for disc chisels, chisel plows, and offset plowing discs. Made to cut down the heavy ridges of a primary tillage tool. Coil tine harrow is suited for final seedbed prep behind a field cultivator or disc harrow.
That's what I was kind of thinking, but the limited information I've found says they mount on chisel plows, tandem disks, and field cultivators... which is why I'm asking here.
I had one on an IH 720 moldboard plow. In corn or bean ground it provided a good seedbed in a single pass. But the diagonal mounting on a plow effectively narrowed the bar spacing as compared to how it would work mounted perpendicular to the line of travel.
We put a buster bar on a 45 vibra shank after an accident between harrows and a tree. You will not be satisfied if you compare the job they do to a 3 bar harrow.
ford farmer,I would be glad to help you out as I had both years ago. I can say more in 3 min than I can type in 3 days. Please call 314 313 9948 GENE
