New Holland 66 baler
I am in search of a plunger arm for my New Holland 66 baler. The arm that is on the main gearbox. Can anyonr help..im located in ohio.
I do not remember if I have a 66 or 68 parts baler. But I think either way it is likely to be the same. I have used a good many parts from it on a NH271 I use so a lot of parts work on many of the NH balers but I am in Missouri
Should be shippable. I parted out 2 of them several years ago here in Ohio and a complete gearbox went to Wisconsin.
I have just gotten a Super 66 that has the same broken , crank arm. It looks to have been welded and repaired more than once. Must be a common thing. Someone said if the wood on the plunger get wet it will swell up and stick.
