(quoted from post at 18:50:13 05/18/17) Thank you, I only have around 7 acres to cut. Didn't want to get too deep into the pocket. Would you want to sell the manuel?
(quoted from post at 21:30:14 05/18/17) It may be that your pitman shaft is not the right length. The sections have to travel across the gap between the guards. When the blade is farthest to the left, the sections should be directly under the guards. When the blade is farthest to the right, the sections should be directly under the guards one space to the right. P.S. I use serated sections which cut my three acres much better.
