Need to do some maintenance on the plunger. Can not get it to move past the end of the stroke.
Don't see any instructions in the manual, after looking on-line it appears that the normal procedure is to remove the wrist pin on the drive end of the plunger arm and then pull on the plunger until it is out (removal of bale wedges etc).
I can't get it to move at all. I'm assuming it is hanging up on some broken bolt/bearing etc underneath it. Anyway to get to all that area?
