RRLUND!!!!!!!! Hesston Half Swaybar Drive Question
Bill VA
Doing a major rebuild on my Hesson 1110 this afternoon/evening and all is going smoothly, except removing the part shown in the pic.
From the parts diagram, it looks like it should slide off the shaft, but it ain't budging.
Is this a simple - use a two jaw gear puller job or is there more to it?
Thanks!!!!!!
Bill
All that holds it is the bolt and big washer. A puller should take it right off. Just put a bolt in the hole so you're pulling against the head of it. I think there's a snap ring then that holds the bearing in the block. That's a flat outside race.
I just got thinking though,seems like that snap ring should be on the outside. When you put it back together,you might want to put it back on that way.
