(quoted from post at 08:45:10 05/09/17) I do a fair job welding but I usually have a real pro do this kind of work . I just talked to such a pro and he said he can remove all the old weld with a scaling tool with his plasms cutter and start over so I think the bar should be okay with that. Now I need to make sure the gear box is good. Where is the override clutch on these? I'm sure there must be one. I really appreciate all the help you are giving!! I will know more once the bar is off and apart.
(quoted from post at 05:13:16 05/28/17) Can you tell me a amount the bar holds in gear oil? The manual gives a starting point and then to tilt the bar etc. The jack is no longer with the machine and I wouldn't have a clue the length.
