Im needing the furtherest back, or the one next to it rake bow for a JD steel wheel rake. Im not talking about the wide bow at the furtherest end, but the one or the other next to it.
Im also needing a small piece that goes under the box of a 1924 IHC grain drill. It mounts down under the box in front. It regulates the flow of seed. It is all one piece. It has a 1in therebouts wide piece that is curved down below another piece that is turned 90o from the piece just described. It might still have a tin piece that fastened on the end of the piece just described. At the top of the piece it has a stud that goes into one of 3 slots. it is pined at the top of the first piece just described and at the bottom of the last piece just described. ITS ALL ONE PIECE. It might be 6in long. Tanks ALOT for any help
