Old wheel disc parts
DY
I need some parts for my 8' wheel disc. It is quite old with no model markings on it. But I think that it might be an International. It has four gangs of seven 16" discs. The gangs are mounted on a square 11/8" shaft. I need the end spacer with a square hole, a square 11/8" nut, and some flat pieces of steel that hold the nut when bent over it. I haven't had any luck doing an internet search. I need the name of a parts company that has these parts. Thanks..............DY
I have an IH-37 disc and I bought my bearings and blades from Agri-Parts Supply. When you get around to tightening the gangs of discs up , have a helper rap the end with a sledge (being careful to not break the cast iron hub) as you tighten the nut. Make sure the threads are clean on both shaft and nut and oil the threads first. Keep tightening; then fold over the flat lock plate.
A hex nut will work just as good as a square one will. And if putting on new blades go with 18" as those 16" are already wore out. And I think Agri-Supply has all the parts you are looking for. And cheaper than the other place.
Look up ASC- Ag Supply Company. I've gotten disk parts from them in the past few years and they have really been helpful. They have a full list of parts and makes, and they are reasonable on shipping and it's there in a couple of days, UPS.......
