JD 709 Rotary cutter
ratface
Hi folks, recently acquired this cutter and it's missing the wheel bearing cap. This style mower has the laminated style tire on it. Don't want water and dirt in the bearing. I have the owners manual but it is of little help in identifying the part number for the cap. Can anyone point me in the right direction for a wheel bearing cap that will fit this cutter? thanks!
You can go to www.jdparts.com, select "previous parts catalog", enter "709", pull up the parts catalog and look it up.
If yours is a 3-point with a caster wheel, the cap part # looks to be C2213E. Looks like the pull-type uses the same cap.
Some $8 at the DEERE dealership.
Thks so much Bob, ordered it today for dealer pickup and there is two per package and in stock. Thanks!
