NH Hayliner 69 - where can I get a a rim and tire?
dogwillhuntv
New User
My neighbor gave me a deal on his Hayliner 69 - still works and makes bales, but really I have had my eye on it for a restoration. As luck would have it the tire blew out after about 400 yards down the road to my place. The baler bounced and the rim is ruined. Anyone have any idea where I can get a replacement?
Left or right side?
Should be a generic implement rim, I think but not sure the left is the common size, the right might be a smaller size.
Paul
Most any farm and home place or tractor dealer will have the rim you need or if it is the 6 hole one most 6 hole front tractor rims are the same so pretty simple to find
What information you did not give that is needed to get proper wheel is if it is a 16" or 15" as both were used on balers, may have even been a 14" and then the right side was a smaller tire so that was a narrow rim, at least 1" narrower than the left side. And if you want to do any restoration you want a correct looking wheel and tire, not something that will mount on the hub but have to be mounted in reverse with the dish turned out instead of in and something that does not make the right side of the pickup run 3" high. In theroy you could replace the 5:00x16" tire that I know the 66 baler came with by useing a wide rim and a new late model pickup tire that you would even have clearance problems with dish turned out and have that side running way high. I do not know if it is the same wheel as the 66-S66 or not but I have some of them.
My NH S69 has 15 inch on both sides. 5.00-15 tire 4 hole on pickup side. 27-9.5-15 6 hole on the other.
