Hydra swing swather
craigco
Do most hydraulic swing swather have their own pump and oil supply for running the reel and cutter? Or does your tractor provide most of the oil? Where is the oil supply if on the swather? Saw one on big iron with a pump so no I'm curious. Thanks
Oil supply is typically in the hollow tube tongue. Tractor hydraulics are used to raise and lower and swing from side to side, so dual outlets are required.
