Front End Loader ID Help
I picked up the attached front end loader in hopes of using in on my David Brown 780. Unfortunately I can't figure out how it would possibly attach. Does anyone have any ideas on who makes the loader, maybe even a make and model? It is really beefy, and I
suspect an older Ford maybe?
Drive the tractor into it, setting the loader frame on blocks. Then it"s easier to visualize how to make mounting brackets to fit.
The frame of your tractor is very solid and you can fasten the loader subframe directly to the sides of the tractor. You can totally forget using that U shaped frame that was used on the previous Ford/Fergi type tractors.
As said, prop up the loader and drive your 780 into it and then fab up some mountings. Hope you have fabrication and welding skills. The power steering cylinder will need some special consideration.
Post down on the Case DB forum and we will help you with the hyds.
(quoted from post at 23:14:06 04/07/17) I picked up the attached front end loader in hopes of using in on my David Brown 780. Unfortunately I can't figure out how it would possibly attach. Does anyone have any ideas on who makes the loader, maybe even a make and model? It is really beefy, and I
in looking for loader for farmall super a
