Antique jd plow question
mosinee dave
New User
Bought a JD 3 bottom plow there are no plow points on it. I never seen the type that need to go on it. They must slip over the steel and is attached to the back by a rod that is still there Must hook to the point on a stud then tightened up and held in place. Where can a person find some of these points? heard there is someone in PA that deals with old plow points.
(quoted from post at 15:43:17 04/02/17) Bought a JD 3 bottom plow there are no plow points on it. I never seen the type that need to go on it. They must slip over the steel and is attached to the back by a rod that is still there Must hook to the point on a stud then tightened up and held in place. Where can a person find some of these points? heard there is someone in PA that deals with old plow points.
Contact Steve Rea of Ploworx:
http://www.ploworx.com/
https://www.facebook.com/Ploworx
http://www.farmshow.com/a_article.php?aid=33044
Hope the links work.
AG
But with none now you will have very big trouble finding some that fit as there were at least two dozen different models each made slightly different and they DO NOT interchange. If you can get a number off the back side of the moldboard might be able to with the plow bottom book figure out what you need. Without that you are up the creek without a paddle.
And he is not yet making all the different styles. And if I remember correctly what he has are close to a hundred each.
I should be able to help at least with figuring out what you need. As for having the parts there is a good chance I'll have what you need unless something uncommon.
Part numbers from the frog, moldboard, and braces would be helpful. Photos work too but part numbers are by far the best. Often hard to find on moldboards but indeed they were put there originally on the back side.
Tyler in MO (IL)
If it takes "Blacksmithed Points", you may be ahead to purchase parts to convert to more modern "High Speed" points with "throw-Away" Shares...Parts are much
less expensive..
