new holland 1432 discbine
foxhoun
I have to replace the lift cylinder on my 1432. I took the old one off but I am looking for a way to get the new
cylinder on.I took it off with a jack but can't quite figure out where to lift the cutter bar into place.Any ideas
would be appreciated.
Thanks
Foxhoun
I used to have a 411 and I can see how it could be a little tricky. I think that you will need to lift in two places. First under the main frame top member, but then also at the end of the header. I would lift the main frame first, and then the end of the header just until the weight comes off the end of the cylinder.
