bad monkey
Bought this old plow a year or two ago. With help from more experienced people here I think I have it figured out on using it. Only issue I have now is a broke coulter disc with a bad axle. I can't seem to find a replacement a dealer was able to find everything but the brass bushing. I tried Shoups but the disc I see they have look like they use a bearing and had design more like a trailer spindle. So I guess my question is does anyone have an idea where I could get a coulter disc and axle that I could use? I need to replace to tube that mounts to the connecting rod that bolts onto the plow so width of the axle I don't think would be an issue as I can change it when I weld it back together. I added a photo of the disc if that helps explain what I'm attempting to fix.
