I'm working om a IH 595 manure spreader.
The angle drive box for the rear beater
is shot past fixing. No gear boxes are
available that we can find soooooo my
idea is to replace the 90? gear box with
a hyd motor. Im sure itll work fine.
Going to be ran with a JD 4440 or 4840.
2250 psi amd 23 gpm flow. Im not sure
other which motor to use other then using
a Low Speed High Torque (LSHT) gear hyd
motor. Need some hyd masters to help me
figure this out. Thanks !!!
