Need David Bradley wagon info
Bje500
New User
This message is a reply to an archived post by Greenfrog on March 19, 2011 at 21:24:40.
The original subject was "Need David Bradley wagon info".
I also am in need of any and all info on these. Pulled my grandfathers wagon out of the woods. Tag says sears and Roebuck model 700715. Tires still hold air. I can see the bottom frame has red paint on it. The wood up top is pretty shot so no paint there. I'm curious if this is the original configuration. I plan on disassembling, sand blasting, and painting this summer. Any info on paint schemes. David Bradley decals. Original wood box design. All the wood is still there should I try to save or use new rough cut timber? Also is it possible to find replacement hubs at all? Also I'm curious what are the specs of this model. Weight rating ect. An old owners manual would be amazing but I doubt that will happen. [email protected]
Ours was red with the DB light green wheels. We made our own flat beds for hay bales, although we later installed hoists like that one to unload ear corn during fall picking time.
Some other manufacturer made those wagons for Sears, maybe Electric Wheel? There may still be hub available - or maybe you just need new bearings that are probably available from any bearing supply house?
