Taylor Way Model 200-239 large disc
This one will be for sale too and I have a complete set of new discs that I believe fit it in addition to the discs installed. I have no idea what this worth either
I don't think either model of disk is very popular, this one is that odd diamond shape they weren't thought very highly of locally, and the JD is the
old pipe model that wasn't much of a design either.
Sorry, few hundred a piece is what you could hope for 'here'. Might be different in another region.
Paul
Thank you for the response. I concur. I will list them accordingly. Neither have been used in at least 15 years. Maybe longer. As far as I can see a good greasing and some new tires and they would be useable. Thanks again for the help. Scrap is only bringing $4.00 a hundred here right now and I would feel guilty scrapping a piece of Daddy's equipment if it is still useable. for another farmer. So I will pressure wash them good come warm weather and set them by the road with a sign on them and see if anyone local is interested.
I have a Taylor-Way 200208 disc which is tandem. Hard to really tell from your picture, as it is quite small, yours looks like an offset? If it is, and has any width, it will take a pretty good tractor to pull it. I think it is a very good disc. I like mine. What are the condition of the bearings? Has it been welded up? That will tell you the worth of it. With another set of blades that will help. Also what is the size? How wide? Tires are an easy fix. These are still used in our area. At a few hundred bucks, if you were close to me I would be interested. Take that for what it is worth here.
Oh, it is an offset. Sorry I was wrong from the tiny picture.
Yea, offset disk has a little more value to the right buyer. They are considered a heavier deeper working disk. If the bearings are good, that can
be better price than I said before!
Will the hyd cylinder go with it? Is that a JD cylinder, or a generic - it looks a little bit JD to me? If it works it has some value added either by
itself or with the disk. If the hoses are rotted and the shaft is pitted then it's just a hunk of iron never mind.
Paul
Tim, email me or call me at 41oh-six niner two-21won two. I might like to have that disc. I'm in Northern Maryland.....
Don,
I will contact you tomorrow. I am working a 12 hour shift today and I was afraid I might wake you if I had called early this morning. I dont get off till 10:15 PM. Thank you.
Don,
I checked the disc and it rotates easily by hand. I apologize for not calling. Our little dog had to have bladder surgery and I have been tied up helping the Bridal Unit care for her. I will contact you soon.
