Allis no till planter
I have a 600 series planter having trouble finding 10 tooth sprockets that go on the press wheel have the standard 18/14 tooth sprockets need to plant 50lbs per acre soybeans on 20" rows will a 16 or 18 tooth sprocket under the seed hopper do the same as the 10 driver and 10 driven chart says 46lbs but running the 18" center rib tire is equal to 50lbs per acre thanks for any help and info
Check with Schmidt and Sons in Mt. Hope, KS 316-445-2103. I have bought quite a few NOS and Used planter parts from them.
I've asked you before and you didn't answer me,have you tried Agco? The part number on those 10 tooth sprockets is 70309838. They're listed on Agcopartsbook dot com.
Parts book
