farmhand grinder mixer
I'm trying to figure out the number on my farmhand grinder mixer. I "thought" it was an F81 but when I look online at parts things don't seem to be the same. unless they made different versions of the 81. the online parts books show windows on the side of the tank that are oblong like a race track and mine are around 4" x 3" rectangle.
I'm trying to find gears for the rear gear box and the newer ones used a 7/8 shaft and mine has 1"
If it has a one inch shaft it is probably a F81D which is a 810. I don't know if 810 is listed on AGCOPARTS book.They also made f81c and one model older If I recall.Model numbers 812 and up are newer and there were changes.So what my work I can't tell you.I had gears for 7/8 shaft machined out and key ways cut for the same deal like yours for my 810 last fall.Scott
