Gehl 95 Mixer Part
I have a Gehl 95 Mix-All Mixer and need to find a Conveyor Drive Gear (17T) part number 6H114D. Is there anyone out there that has one of these mixers with this part that they would be willing to sell or does anyone know a place where I can get this part? Thank you.
I'll give you two places to try. First, Call Fry Machinery 570-546-3968 near Williamsport, PA. Second, call Finger Lakes Equipment at 585-526-6705. Yes, he is a baler man only but he may know of someone in the Mennonite community that does grinder mixers.
Might have to get that built-up and machined to original tooth configuration. How are the mating teeth of the drive gear? They might need some work also. Looks like the teeth weren't in full contact with the gear that drove it. Any way to adjust that?
German Bliss equipment has a lot of old stock parts for Gehl mix mills. I know someone who just got a gear for his mix mill it was pricey but he was happy to find it.
I chipped a tooth on my mix mill a couple years ago and I ended up welding it up and grinding a tooth out of it.
Gehl was kinda bad at having open gears and a bit wobbly of a setup to hold them in place, esp on the unload arms. Lot of folk put in hyd motors to keep them running, was easier than fiddling with all those open gears. And poor supprt brackets.
Paul
