Brown Swiss
On my Meyer spreader the right bottom auger is moved back 1.25" from the front, is this okay or normal or is there something going wrong, I feel like I am getting OCD over this! LOL I checked the T post and do not see any broken weld and the bushings are good there, the auger is what has moved not the shaft, I checked the front where it is in the sprocket it it has not moved. I called the Dealer at Strawberry and asked one of the guys in the shop and he said a bolt has sheared off but for the life of me don't see any place that a bolt would go through it. My last load I had to go up a steep grade and it was bouncing some, and I would think when I fill it and turn it on it should shove the auger forward. So am I getting to worked up about this or not? Thanks in advance.
