Just started getting a MF 62 3 bottom plow ready for next spring. Going to turn over an acre of field grass and figure I will need the coulters. Plow came with two of the three coulters and I have a 3rd off an older Ferguson plow. All 3 need new hubs and/or blades but not exactly sure what to buy or where to get what I need.
The blades are pretty worn but think they are 15" and looks like the max that will fit would be 16". The Agri Supply web site doesn't really give you enough info to match blades and hubs other than the one below that fits a 17" blade which won't fit inside the forks. I can deal with the 3/4" center bolt but 17" or 20" blades will not work.
Any ideas?
Coulter Hub
Any ideas?
Coulter Hub
