sickle mower ford 501
TimPa
my transport bar fell off in the field and can't find it. looking for a transport bar for a ford 501 model 14-92. thanks
Run across the field a few times with the tractor, then stop and look at your tires......
Tim, I lost mine several times. Got some exercise in walking the fields to find it. Finally wised up and painted it day-glo orange, which aided greatly in recovery. Good luck.
if you do small square bales it will probably show up between the knives on your baler next year. I think the tire trick mentioned below only works with hay hooks
