New holland 442 lube
Just picked up a very used 442 disc more and manual is on the way but in the meantime can anyone answer the question as to the correct gearbox. Bar lube?? There seems to be very little play in the discs but seems noisy when running. Normal? Thanks in advance
CHECK YOUR BOOK!!!!!!!! Some of those things use the lighter gear (hydraulic) lubricants......
Ditto...
Heavier lube will not flow quickly enough when the bar has been elevated for transport.
Rod
