Hesston 5800 round baler
Working on a Hesston 5800 round baler. Removed the belts to see if they needed any work and they measured 370 inches and are supposed to be 380 inches. I am sure this isn't a problem it will just cause the baler to make a little smaller bale which is fine. But I also noticed the tension springs on the sides were all the way tightened. My thought is that with the shorter belts the tension springs shouldn't be so tight.
I also noticed that the scraper deflector is frozen and is in the upmost position. Is it a big deal that it doesn't move down when the bale gets bigger. I did have a little problem last year with hay getting around the roller and stopping the belts but not till the end of the year. I assumed the hay was a little to wet or chain and sprocket issue as they all needed replaced and I have replaced all of them. The belts look good no cracks and they don't look weathered. They are a little slick not sure if that would make them stop turning with a half bale in the chamber. Thoughts thanks.
I have also read where some people have sprayed some kind of rubber paint on the rollers to give them more traction to turn the belts and on the bottom roller that starts to turn the bale after the core is made. Anyone used this and does it help. Thanks
If your belts are 10 inches short then either they aren't on the rolls in the right order or something else is screwy. 10" is a LOT.
Checked the ops manual. Belts are on rollers correctly and everything looks good. I believe that who ever had the baler before me must of cut out a piece on all the belts.
Is there any paint or something I can put on the rollers to help grab the belts or the bottom roller to help roll the bale. My problem may be fixed with all the new chains and gears. I am just looking for ideas to do while I have it apart. Thanks
Shoup sells a product that is supposed to aid traction and reduce slippage. It's Shoup item RB10060. No clue on price.
